Difference between 2l 8v 2e and ADY engines?
This is where you ask general or specific technical questions about your VW or Audi...
Postby AxeMan on Sat Apr 02, 2011 8:46 pm
Ex.1967 Mini Cooper,1988 Vw Citi Golf 1800Sport,1997 Vw Golf 3 GTi exec,1996 Opel Kadett 200iS,2005 Suzuki Bandit,1976 Suzuki TS50,1983 Kawasaki z750,1992 Kawasaki ZZR400,2005 Vw Citi Golf 1.4i,1997 Vw Golf VR6 exec,1982 Honda CB750f,2002 Vw Golf 4 GTi
Current: 2006 Vw Golf VeloCiti
AxeMan
yuppie dicer
Re: Difference between 2l 8v 2e and ADY engines?
Postby pynoxim on Sun Apr 03, 2011 11:58 am
ADY : Longblock, MP9 Short Intake sans MAP sensor
2E : Longblock, Digifant
Basically, they're the same motor with different fuel injection systems, also, the 2E's are older than the ADY's.
Current Vehicle : '04 VW Jetta 1.8T Highline Executive (162kw/348nm)
pynoxim
Postby Kazuya on Mon Apr 04, 2011 8:25 am
i speak under correction but dont some 2e's come with forged steel cranks?
1984 Toyota 1.8 sprinter, branch, sides - SOLD
1984 Mk II GTS 1.8 8v branch, flowed head, big valve, 288 cam - STOLEN
1985 Mk II CSX ABF 288 cams 45mm ITB's Image
Kazuya
XV Extreme
Postby poloplayaWP on Mon Apr 04, 2011 8:37 am
pynoxim wrote:ADY : Longblock, MP9 Short Intake sans MAP sensor
ADY was not MP9.Ran either Siemos or Digifant cant remember.ADY short intake which gives more KW but less NM.2E had a different intake and yes as Kazuya said came out with a forged crank.ADY and AGG have less wear and tear over the 2E as they are are newer motors.
2005 Polo 1.9 TDI Sportline 130kw 420nm
EX
1998 Polo Tech 2.0 8v-given to brother
1978 Beetle 1.6 Twinport-sold
1998 Polo Playa 1.6-sold
1984 MK1 Golf 1.3-sold
poloplayaWP
veteran dicer
Postby pynoxim on Mon Apr 04, 2011 8:57 am
Yes, Siemos EFI, which is very similar to MP9 sans the MAP sensor and the different ECU.
pynoxim
Postby KrazyKid on Mon Apr 04, 2011 12:34 pm
so what to buy?
Ex: '93 toyota twincam
Ex: '99 Golf mk1 1.4i
Current: '01 Golf mk12E Mp9
http://www.facebook.com/media/set/?set= ... 1942053404
KrazyKid
taxi driver
Postby poloplayaWP on Mon Apr 04, 2011 1:03 pm
I suppose any one is good but if you want something thats newer then go for the ADY or AGG motor.If you currently have a MP9 motor in like 1.4 or 1.6 then go to Mikes,block and head with not intake and extras on goes for R2950.....otherwise R3950 for complete motor with extras and intake.
EX
poloplayaWP
veteran dicer
Postby kmg4real on Mon Apr 04, 2011 10:54 pm
ADY:
Comes with Mahle pistons
Has 60-2 trigger wheel and pickup for wasted spark.
Longblock
2E:
KS pistons
Steel crank
Longblock
'02 Citi Golf: BlaqSmithe (2l 16VT 233HP 288Nm)
'11 BMW 320d
Ex - '08 BMW 320i facelift
Ex - '07 C2 iPlay
Ex - '07 G5 GTI
Ex - '04 A4 1.9TDi 6 spd
Ex - '02 Chico 1.4i
Image[img]
kmg4real
tricycle racer
Postby AxeMan on Tue Apr 05, 2011 9:04 pm
Iam going to be fitting:
iTB's
280 Billet cams
etc
And i just wanted to know which engine will give me the better power... Iam not so worryed about the FI system it uses, just the overall outlook of the 2 motors for what i want to use it for...
AxeMan
yuppie dicer
Postby 8V-T on Tue Apr 05, 2011 9:19 pm
Both motors are rated at 85kW and 166Nm ATF at the coast.
Same bore, same stroke, etc.
There will be very minimal differences in outputs if modified the same way, so take your pick of what motor to buy and modify.
___________________________________________________________________________________
'89 Mk2 Jetta, 2 litre 8 valve X-flow turbo
'96 Mk3 Golf VR6, zorst, 17's airbox mod, that's it
8V-T
shopping trolley racer
Postby Prevy on Fri Apr 15, 2011 2:00 pm
I noticed that you had posted a 1997 golf 3 GTi as an ex car, this car had an ADY engine (mp9), actually rated 88kw at the flywheel compared to the pre 1996 2E engine that makes 85kw, with a digifant intake.
The blocks are basically the same, the heads and intakes are different.
I stand to be corrected, but thats my understanding, I own a 1998 golf 3 Gti, so this is after some research.lol.
1998 Golf MK3 GTi (Stock Standard)
Prevy
tricycle racer
Postby poloplayaWP on Fri Apr 15, 2011 2:24 pm
Prevy wrote:I noticed that you had posted a 1997 golf 3 GTi as an ex car, this car had an ADY engine (mp9), actually rated 88kw at the flywheel compared to the pre 1996 2E engine that makes 85kw, with a digifant intake.
AFAIK the only car in SA that had teh ADY motor was the MK3 Cabrio.The MP9 version MK3 GTi's had a AFW motor.
EX
poloplayaWP
veteran dicer
Postby Prevy on Fri Apr 15, 2011 2:34 pm
I know I am new at this, but I believe that the convertible actually came with the afw motor.
Prevy
tricycle racer
Postby poloplayaWP on Fri Apr 15, 2011 5:15 pm
Prevy wrote:I know I am new at this, but I believe that the convertible actually came with the afw motor.
Cabrio had short intake and only ADY and AGG have short intakes.
EX
poloplayaWP
veteran dicer
Postby AxeMan on Mon Apr 18, 2011 11:43 am
And the 2l 8v AGG motor?
AxeMan
yuppie dicer
Next
Return to Technical Questions
Users browsing this forum: Bing [Bot] and 1 guest
