Ubuntu Linux
This is where you can find out about the lastest hardware/software & gadgets on the market.
Ubuntu Linux
Postby Krakie on Fri Nov 11, 2011 11:33 am
Is/has anyone used it?
Sent from my Desire HD using Tapatalk
Current: 2007 Seat Leon FR
Ex: 2000 Golf 4 GTI
Ex: 1994 CTi 2L 16V (under construction)
Krakie
XV Ultimate
Re: Ubuntu Linux
Postby 16v_twisted on Fri Nov 11, 2011 2:05 pm
last time i used it was ubuntu 8 or 9
its not bad somware between windows and mac
for basic browsing and movies and stuffs its gud
if u wana so more u gna need to brush up on ur linux skills
T.W.I.S.T.E.D
- "Im Not Normal Im a Retarded Genius"
Mk1 2Door GT | 1.8 16V ITB's | Ex Mk1 1.8 CTi | Ex Mk2 1.8 GTS
16v_twisted
shopping trolley racer
Re: Ubuntu Linux
Postby JIHAAD on Fri Nov 11, 2011 2:19 pm
i think its gud you can run windows inside it ,but you have to use virtual box.cool thing about using virtual box is you can have multiple os systems and also if it messes up its a 5min installation because you can use a image
If everything comes your way, you are in the wrong lane
JIHAAD
street dicer
Re: Ubuntu Linux
Postby 16v_twisted on Fri Nov 11, 2011 2:40 pm
JIHAAD wrote:i think its gud you can run windows inside it ,but you have to use virtual box.cool thing about using virtual box is you can have multiple os systems and also if it messes up its a 5min installation because you can use a image
yeah u can but if u going to be gamin i wudnt recomend any linux as little games are compatable
if you runing windows i would sugest runing ubuntu as a vm to play around with first
that way u can see if you like it
T.W.I.S.T.E.D
16v_twisted
Re: Ubuntu Linux
Postby slang on Fri Nov 11, 2011 4:11 pm
Im using it at the moment. Whatsup?
2010 Golf6 Tsi 90kw
slang
taxi driver
Re: Ubuntu Linux
Postby supey on Fri Nov 11, 2011 5:01 pm
I was gonna use it, installed an everything, but my pc not fast enuff for compiz Fusion ... so yah, I haven't used it in a while. U can use windows apps within it via WINE ... plus it get's complicated, to a point that u'll have to have programming skills to get ur hardware to work. :pale:
for VW engine codes
Ekta -> VW part numbers. http://87.118.230.251/ Use Google tranlate to getit to english
supey
Re: Ubuntu Linux
Postby Krakie on Fri Nov 11, 2011 5:51 pm
I'm thinking of using it on a netbook. The netbook will only be used for browsing and some series. No gaming. I guess I could do a dual boot as well. I made a live usb and played around with it a bit, but just wanted some other opinions.
I guess I will give it a proper go when the netbook arrives.
Seems like a reasonable alternative which is less resource sapping. Any other opinions welcome :thumleft:
Ex: 2000 Golf 4 GTI
Krakie
XV Ultimate
Re: Ubuntu Linux
Postby supey on Fri Nov 11, 2011 6:14 pm
Rather get a windows copy bra. U'll find ubuntu very strenouis. Its like a mansion with all the furniture scattered. U'll struggle to roam around. Like I said, u'll struggle to ge t some hardware to work etc. Rather do a dualboot. That's what I did. And then u partition ur drive into 3. One for storage, 1 for ubuntu, and 1 for windows. U can even rearange ur partition with a partition manager after the install. But I really want compiz fusion. Also wanted a nice downloader from usenet that can run a rss, but the ones on ubuntu are too complicated
for VW engine codes
supey
Return to IT Junkyard/Helpdesk
