Striping paint
This is where you post all your technical topics about body work, body kits and body styling.
Striping paint
Postby zeer on Wed Nov 09, 2011 5:12 pm
Hi guys wots the best method / materials / products to use to strip a shell down to its bare metal
or does nybody have a link where this process is mb documented...lokking to do a DIY jobbie before sending the shell of to a panelbeater
Built in Germany....perfected in my garage
zeer
bmx racer
Re: Striping paint
Postby mornecameron on Thu Nov 10, 2011 12:34 pm
Its called paint stripper! its a liquid... you'll need a few bottles worth for a whole car. Should cost about R20 per bottle at a hardware shop. I used it once to strip the paint off a metal door frame. works wonders. just apply wait till it peels or bubbles off and then wipe with clean cloth and water. It doesn't damage the metal at all. I love this stuff would bet my ride on it! lol :salut: O ya, best part is. it take you less than 2 hours to do the whole car.
Current: VW Polo 1.2Tsi Highline (2015) - 81KW
Ex: Audi 2005 3.2 LTD Edition v6
Ex: Audi TT 1.8T 2001(Chipped and Tuned)
Ex: Audi A4 2.0 2008
Ex: Nissan 350z HL Fair Lady 2005
Ex: BMW E46 325i M Sport 2005
Ex: BMW E46 320i 2001
Ex: POLO Comfortline 1.6 2005
mornecameron
yuppie dicer
Re: Striping paint
Postby SWISS on Thu Nov 10, 2011 1:25 pm
mornecameron wrote:Its called paint stripper! its a liquid... you'll need a few bottles worth for a whole car. Should cost about R20 per bottle at a hardware shop. I used it once to strip the paint off a metal door frame. works wonders. just apply wait till it peels or bubbles off and then wipe with clean cloth and water. It doesn't damage the metal at all. I love this stuff would bet my ride on it! lol :salut: O ya, best part is. it take you less than 2 hours to do the whole car.
Even better part is...makes for a really great High :twisted:
Daily - Audi A3 2.0T FSI
EX - '91 Golf mk2 9A 16v :cry:
EX - Golf 4
RIP - '91 Edition One Passat GT 9A 16v :cry:
SWISS
Re: Striping paint
Postby zeer on Thu Nov 10, 2011 1:52 pm
:thumleft: thanks guys....i also found a old mag that has a restoration artical in nd there they say i will need to sand it down with a mid speed buffer and 800 grit paper...do i do this b4 or after using the paint striper?
zeer
bmx racer
Re: Striping paint
Postby mornecameron on Thu Nov 10, 2011 2:06 pm
zeer wrote::thumleft: thanks guys....i also found a old mag that has a restoration artical in nd there they say i will need to sand it down with a mid speed buffer and 800 grit paper...do i do this b4 or after using the paint striper?
You'd only use that if there is scratches that needs removing but if theres no scratches then you only use the paint remover
mornecameron
yuppie dicer
Re: Striping paint
Postby zeer on Thu Nov 10, 2011 2:14 pm
Cul...will this also remove ny bodyfiller there maybe :scratch:
zeer
bmx racer
Re: Striping paint
Postby SWISS on Thu Nov 10, 2011 2:16 pm
Also remember, the paint stripper will take it down to bare metal. You will wanna get it in teh shop asap for primer or it will start rusting :shock:
EX - Golf 4
SWISS
Re: Striping paint
Postby mornecameron on Thu Nov 10, 2011 2:16 pm
zeer wrote:Cul...will this also remove ny bodyfiller there maybe :scratch:
With filler I think you need rubbing compound to smothen it out
mornecameron
yuppie dicer
Re: Striping paint
Postby zeer on Thu Nov 10, 2011 2:29 pm
Also remember, the paint stripper will take it down to bare metal. You will wanna get it in teh shop asap for primer or it will start rusting :shock:[/quote]
yip thing is i got screwed with the last PB nd so im just trying to save some cost b4 it goes off for respray so i appreciate the help guys.....so ny other advice u guys can offer will b gr8 :cheers:
zeer
bmx racer
Re: Striping paint
Postby SWISS on Thu Nov 10, 2011 2:33 pm
zeer wrote:
IvanSK4 wrote:Also remember, the paint stripper will take it down to bare metal. You will wanna get it in teh shop asap for primer or it will start rusting :shock:
TBH, if i were you, i would just sand the whole body down, fill any imperfections and sand till smooth. Them rattle can spray primer and sand smooth. Then send the primered body in for spray. Don't bother stripping the original paint as you will prob get rust issues.
EX - Golf 4
SWISS
Re: Striping paint
Postby zeer on Thu Nov 10, 2011 2:44 pm
thank u sir...thats the kind of help/info im looking 4
zeer
bmx racer
Re: Striping paint
Postby mornecameron on Mon Dec 19, 2011 1:28 pm
Just an update. I did my mags a few weeks ago. I used paint stripper and then primer-ed once done. paint stripper cost R45 and a blikkie primer is R50. and it worked wonders cause My mags looks crazy insane
mornecameron
yuppie dicer
Return to The Panel Shop
